how do i fix this ,hope some1 can help,cant seem to find earlier posts of this
Just look the forum search box and type in Powervcr and all the posts will come up.
If you are comfortable with the reg its easy to find. Do a find on powervcr. When you reach the right spot it will be obvious. You will see the screen capture settings, play and cap audio values etc... and they can all be changed.
nough said!
Registry cleaner.
By HotDamn! in forum ComputerReplies: 13Last Post: 15th Jan 2010, 22:07 -
Registry Cleaner
By BLSAMPLES in forum Newbie / General discussionsReplies: 5Last Post: 11th Oct 2009, 09:45 -
Registry problem?
By alintatoc in forum ComputerReplies: 8Last Post: 4th Jul 2009, 17:23 -
Looking for a trial registry cleaner!!!
By kemcel in forum ComputerReplies: 13Last Post: 30th Oct 2008, 01:50 -
Registry corrupted
By zoobie in forum ComputerReplies: 9Last Post: 11th Jun 2007, 11:57
