    Jul 2001
    Dallas
    After I converted my divx to mpeg I split it in half and burned a vcd. Towards the end of the second disc the sound was off by about 30 seconds. Does anyone know what causes this
  2. Banned
    Jun 2001
    UK
    Did you check the original AVI for junk frames with Vdub ?
    Jul 2001
    Dallas
    yes the divx plays fine
  4. Banned
    Jun 2001
    UK
    Plays fine means nothing, they all play fine even with junk frames. It only takes a glitch in the movie to cause lip sync during conversion or cut.
    You may want to save out the audio using Vdub, then use that later with TMPGEnc
    Audio > full processing mode
    Audio > conversion > 44.1Khz
    SAVE WAV
    if this fails, you may have to save and convert later
    Audio > direct stream copy
    SAVE WAV
    Jul 2001
    Dallas
    really I did not know that. Ok I will try that
  6. you can test for bad frames here:
    http://www.digital-digest.com/dvd/downloads/virtualdub.html
    scroll down to mp3_freeze version then scan for bad frames and extract
    "Today is only yesterdays tomorrow"
  7. Banned
    Jun 2001
    UK
    No, get the version from Kazaa, it has a few more enhancements
  8. What enhancements would that be KJ?
    What is it called Virtualdub???version?
