Hello all, I recently obtained a DivX with ac3 soundtrack which is very good audio/video quality. I have managed to convert teh ac3 track to normal mp2 format. My problem is that the resolution of the avi file is quite high, 640x352. I tried to maintain the resolution in my conversion using Tmpgenc but when burnt to CD and played on my Toshiba 220 the video was all scrambled. Do I have to abide by a certain resolution for XSVCD? I dont want to be limited to 480x480.
Allan
Yes (X)SVCD requires the use of 480x480 or 720x480. I would use 480x480,the pixel count is the same as your 640x352. 720x480 probably would not be improved but reqiures no larger file size.
Use 480 x 480, and then under your aspect ratio properties, set it to 1:1 VGA, as well as the first Keep Aspect Ratio choice
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Youtube HD Resolutions
By bseos in forum Video Streaming DownloadingReplies: 12Last Post: 14th Oct 2011, 11:50 -
Screen Resolutions
By ranosb in forum Video ConversionReplies: 4Last Post: 25th Aug 2009, 03:04 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 13:13 -
Question about resolutions
By ShinKyo in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 09:44 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
