I have question? I want to covert a MP3 into a MPEG-2. Ok I am sure you can do it but the real important question is. Will a MP3 converted Mpeg-2
play?
hmmm. not sure what to make of this.. Are you referring to Mpeg1 Layer 2? (which is used for audio in vcds and svcds) or are you referring to Mpeg2 (which is for video only). What exactly are you trying to accomplish?
Originally Posted by liquid217
hmm well once again, you didn't mention how long it actually is. One solution (its kinda far fetched), is to load the audio file into tmpgenc and then for the video, just load a picture or something. use the svcd template and then lower the video bitrate to 2k/sec (that is incredably low, but thats the point)
Also, this will only work if your dvd player can play svcds (since the video can be variable bitrate...vcd cannot)
doing the math, with a video bitrate of 2k/s , you should be able to fit 400 minutes on one disc
Not sure if a dvd player can handle such a low bitrate on video, but its definitely worth a shot. -
FOUR STARS! I could even load a picture that would go with the book aka
a picture a Tolkien with the Hobbit book and so on..
Do MPEG's and other video's have multiple metadata fields like MP3's have?
By HitTheRoad in forum MacReplies: 5Last Post: 30th Oct 2011, 09:20 -
Converting audio in mpeg-4 video file to mp3?
By lazopper in forum AudioReplies: 2Last Post: 21st Aug 2011, 05:27 -
Mpeg 2 video to mp3
By mobie29 in forum Video ConversionReplies: 2Last Post: 22nd Sep 2010, 13:28 -
How to convert MP3, MPEG, AVI to Windows Media Formats (algorithm)
By Nemo_wf in forum Video ConversionReplies: 0Last Post: 13th May 2010, 06:05 -
Converting audio from a mpeg file to a mp3 file?
By hrace in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 16:15
