I understand how to change between AVI and MPEG/MPEG2, but how do I reduce the size of the resulting file in SVCD format so that the movie will fit on two disks? I get a file that is either way too large (2+ GB) or 4-5 files of the right size.
Thanks!
get a new version of tmpegenc (V2.0 upwards) and use the guide in the how to convert section, this tells you how to split the movie into 2 sections whilst encoding and also adjust the encoding bitrate so that your resulting 2 mpegs will fit exactly on to 2 700mb cd's
see here for the guide http://www.vcdhelp.com/tmpgencsvcd.htm
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Convert DVD to MPEG2-TS with Subtitles
By lalero in forum Blu-ray RippingReplies: 0Last Post: 4th Nov 2010, 09:21 -
can not convert to mpeg2-dvd
By lartomar2002 in forum Video ConversionReplies: 4Last Post: 28th Sep 2010, 12:07 -
Convert DVD back to MPEG2?
By ArthurDaley in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2007, 02:02
