here is my situation i have kazaa lite live in australian and have telstra for an isp. I don't know hwo to share files which is why i have download speeds of 0.5kb/sec and when i am off the computer and off line speeds of aobut 0.001kb/sec. I don't know how to share files i have many files in my shared folder except kazaa still says i am sharing no files. I also can't access the "my kazaa" section but when i go to my kazaa it says i have 52000 media files except when i click on all or any part in my kazaa it just says kazaa isn't responding and it won't load and i can't access it any more without exceting and starting up again only to find the same thing happen over and over. I also can't check which files on my computer can be used as a shared file because when i try to access that section of kazaa it just freezes. can anyone please help me!!!!!!???????
Results 1 to 21 of 21
wasup
try uninstalling it and then install it again, because file sharing programs let you set the files to be shared when they are installed. if kazaa still gives you problems, try another file sharing service like www.winmx.com or www.grokster.com they are probably better than kazaa anyway.
At your d/l speeds I would rather draw the movie and make a flip book.
Sorry that wasn't me. The program will share by default unless you purposely choose not to. -
Choose not to and then set it up in the options later........
52000 files is a lot for anything to handle.
I reckon its sharing your complete harddrive there.........
System files and all......... -
well the my kazaa section is now workin fine i tried to uninstiall and the install it again but nothing changed the my kazaa section now has 55 000 media soucres but still it says i am not sharing any files??????
wasup -
i am trying grokster and have already 3000 things in the my grokster section and still am not sharing any files but that may be because i have no files in the my grokster thing on my desktop can someone tell me how your ment to share fiels wth grokster?
wasup -
now am sharing 17 000 files still with very slow download rates and i have noticed that when you have less downloads each individual one is quicker
wasup -
Before you run Kazaa Lite, you must first run "pseudotr.exe" PseudoTrack should be configured for all your settings, including your shared folders. Older Grokster,Kazaa should be uninstalled and Ad aware used to remove any spyware "Before" installing Kazaa Lite 1.72e... -
Originally Posted by Anime_Fire
Originally Posted by KingJohnwasup
The computer has to be on, and online, to download anything. How do you expect to download files with the computer turned off ? A lot of dial up account providers terminate your connection after several minutes of activity or if you ar online for 2 hours. You then have to reconnect.
Craig -
Originally Posted by Anime_FireThis is proboly a ice cream induced thought so i can not take no control for the above statment. :P
At 0.001kb/s it would take 57 days to download a 5mb song.
Craig -
Originally Posted by craigtuckerThis is proboly a ice cream induced thought so i can not take no control for the above statment. :P
Shit that would suck it takes me about all of 5 minutes to get a whole cd.
I am on broadband so I dont get disconnected. I know some dialup accounts do though.
Craig -
If nothing else works, try using kazaa instead of kazaalite. As far as not sharing files and having lower transfer rates goes, I think the discerning kazaa user who sees that you are getting decent uploads off him will check to see what you have, so he can get good download speeds off of you. If he find you're sharing nothing, he'll disconect you. That probably isn't the case for you, though; I'd personally never bother checking what anyone who was uploading at .5 kbps from me was sharing.
HD share, any experience?
By sakari53850 in forum Video Streaming DownloadingReplies: 7Last Post: 17th Aug 2011, 04:13 -
Help please, share video file?
By AceK7 in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2011, 18:54 -
A way to share files by default in Windows when connecting new disks?
By Talayero in forum ComputerReplies: 5Last Post: 6th Jun 2011, 08:09 -
How to share large data files between two computers?
By Rudyard in forum ComputerReplies: 16Last Post: 16th Jul 2009, 22:41 -
Share Media- Hardware
By Cookie1979 in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2008, 14:24
