I am getting frustrated at all the god damn purple coasters I am ending up with. It seems the Pioneer is very finicky about its media.
I have tried twice to burn using DVD-Rs by TDK, and I get the following error:
ASC 08 ASCQ: 01 ERROR -10 at Sector 665184
Is it the media?
Is it the burner?
Is it me?
Arghhhhhhhhhhhhhh![]()
I used Memorex DVD-R and everything worked just fine -
This is quite upsetting -
http://www.pioneerelectronics.com/Pioneer/Files/PIB222501_Drives-ChangeATAPICntrllr.pdf
Is this why I am making coasters? -
On the adaptec website you can find a program that will check and update the ATAPI files for 2000.
Also, make sure the drive is in the proper operating temperature. If the room is to warm, the drive could fall out of spec and this could be why you are getting coasters.
I would start with these two items because they are the easiet to fix.
BTW....is this a AMD or Intel processor? -
Hmmmmm.
So this is common for win2K ??
If thats the problem, I may opt for a better oS.
I guess I am confused as to why it works with Memorx media, and TDKs do not work. I dont see how the ATAPI could dicern between the two.
Any thoughts?
Thanks for trying to help me -
I will definitely check out the link.
New BD Burner--Just Coasters--Suggestions?
By wwaag in forum DVD & Blu-ray WritersReplies: 1Last Post: 8th Dec 2010, 19:24 -
HP DVD+R coasters...
By lost123 in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2010, 16:48 -
Verbatim Coasters
By hech54 in forum MediaReplies: 6Last Post: 25th Jun 2009, 18:16 -
Making some expensive DL coasters (Help!)
By nchd in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2009, 13:50 -
Getting coasters with Nero 7???
By dagerousdave in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 20:12
