Here is the problem when I use AVI2SVCD to encode divx to svcd via cce 2.50 . The whole process goes fine , without any problems . The problem is after im done , and i try to watch it , i get a message that says AVISource: failed to decompress frame xxxxx . It happens in various parts in various movies . The thing is that when i use tempgenc , to encode the same divx file , everything goes great and it has no problems . Any help is appreciated , and thanks in advance.
Ark,
have u tried using tmpgenc in dvd2svcd (avi2svcd) instead of cce?
if u're going to run cce as the encoder, try converting from (or checking ) Convert from Divx 3 to Divx 4,
and check ReSampleAudio (44100)----< or something like that under the encoder tab or something.
Is the divx file Read Only?
I've been using avi2svcd using Kwag's template and so far has given me very good results.
ztr
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 12:53 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
