OK, I've seen a lot of posts here and at other forums looking for help in getting DWS to let you use an AC3 audio track along with your Mpeg2 Video.
Well I've done just that and it plays quite well on both PC's and consumer players !!
The assumption here is that you are archivinga DVD and want to preserve the audio as is, that said, here goes ....
Use DVD2Avi to create the D2V that you will use in CCE or TMPgenc, configure DVD2Avi to demux your selected audio track, NOT decode. This will extract the AC3 as is.
Encode your video only stream, giving you an M2V file.
Now, you'll notice that when DVD2Avi demuxed your audio track that it added some info to the file name. Most important in this is the DELAY info. If you were to mux this AC3 track back in with your video, it would be out of sync.![]()
You can use a little tool that you can get from Doom9.org to fix this, it's called "AC3 Delay Corrector". Run your AC3 through this to clean up any delays.
To mux the audio and video together we will now use BBMpeg which has direct support for muxing AC3 and Mpeg2.
Load up your AC3 and M2V files, set your program stream type to ~DVD and mux away.
You now have a complete Mpeg with an AC3 audio track.
When in DWS, after you've laid out your DVD and your ready to burn, make sure to check the "Do not convert compliant file" checkbox. And burn your DVD.
The result is a beautifull DVD complete with AC3 audio ...
Works like a charm 8) ........
Results 1 to 9 of 9
Da MoovyGuy
Exactly where is the option "Do not convert compliant file"?
I'm using the latest demo 1.2...trying to put together a guide. -
Above the checkboxes for saving the video and audio files that are produced in making the image. Right side of the "Finish" window.
A link to the Doom9 AC3 tool?I don't have a bad attitude...
Life has a bad attitude! -
Originally Posted by leeboDa MoovyGuy
Originally Posted by Baldrick
There is no legit demo of version 1.2, it's still 1.0. Only 1.2 has this feature, I guess that's why you can't see it.
I could email you a screenshot if it would help ....
Later 8)Da MoovyGuy -
moovguy: Yes it was 1.0 so please email a screenshot...so I can add it to my guide at least. Anything else that is entirely different in 1.2?
As to what's new, as I didn't really use 1.0 very much I can't really say as it hadn't met my needs until 1.2 ...
SorryDa MoovyGuy -
Anything else that is entirely different in 1.2?I don't have a bad attitude...
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 09:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55
