  1. Tech Info:
    P4 1.3 GHz
    256 PC133 Ram
    6 Units Yamaha 24x10x40 CD R/W
    3 Tekram SCSI card
    HDD 20GB 7200 rpm
    Padus Disc Juggler 3.5.818
    Nero 5.5.8.2
    Problem:
    When I burn 1 cd I was able to get the maximum speed of 24x...but with 6 CDs it is automatically downgraded to 16x...
    The seller said that scsi automatically downgraded the speed from 24 to 16.
    How can I get the maximum speed of 24x when burning 6 cds at the same time?
    I tried burning it with many types of CDR but gets the same result
    Plz Help mee
  2. The only way you are going to get what you are looking for is firewire. Diskjugger HAS tested up to 32 40x CDWRITERS simultaneously when connected over firewire. We just went through all of this with them.
    Realistic limits are
    IDE 4 drives
    SCSI 4 drives
    Firewire 16 drives
    I have no idea why this is so, nor Do I even want to speculate. Just have spent all day working on this. Scsi should be able to handle the job with no problems at all. But for some reason, it doesnt. Get a firewire card, and firewire converters and go about your way. www.ioi1394.com
    You can keep your current drives.
