Is there a card or external; device out there that I can get which will allow me to capture video from devices with a/v output (white and yellow plugs), and capture TV?
If not, what two seperate devices could I buy for the best results?
Many have composite in for video and your audio card will have line in for sound.
You'll probably need and adapter for audio though.
I've captured from VCR using that method. -
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
I was just going to say, "All-In-Wonder Radeon?"
I used this before my "upgrade"...
At one time I had cable into the tuner (to capture TV), and both S-Video and Composite plugged into the handy patch cord, and I switched from the 2 audio sources.
The AIW series is the only "everything" solution, though there are others out there that have both TV tuners and video ports (though they are external, USB-type stuff).
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 18:46 -
How do capture cards get audio when using tuner
By GLE3 in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2010, 14:33 -
A good video capture tv tuner software for Ubuntu?
By Milardo in forum Capturing and VCRReplies: 0Last Post: 11th Jun 2008, 16:05 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 02:16 -
Are all US tv tuner capture devices going to ATSC models??
By yoda313 in forum Capturing and VCRReplies: 6Last Post: 13th Jul 2007, 15:26
