When you rip a DVD to VCD, what video bitrate do you use in TMpeg, and how many discs do you use?
Constraints for MPEG files in VCD
The MPEG standard allows many variations for the stream format. Not all possibilities are useful for implementation in the Video CD decoder, so additional restrictions are made for VCD compliant MPEG sequences. The most important ones are:
-Each pack has the length of a CD-ROM/XA Form 2 sector, i.e. 2324 bytes
-There is exactly one video stream and one stereo or two mono audio streams in each sequence
-Video streams have a bit rate of 1151929 bits/second
-Audio streams are in Layer 2 and have a bit rate of 112000 bits/second per channel
-A video stream must have one of the following resolutions and frame rates:
352x240, 29.97 Hz NTSC
352x240, 24.976 Hz Film
352x288, 25 Hz PAL (only in VCD 2.0 and later)
-The distance between two subsequent I-pictures must not be greater than two seconds
Anything else, is NOT a compliant VCD, but rather an XVCD.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Settings for My XVCDs...
For a typical 90-110 minute feature that I place on a single disc:
Video
- 352x240 pixels
[NOTE: I recently discovered my Dreamcast is capable of playing 352x480 pixels though]
- 800-950 kilobits per second Constant Bit Rate Video
- High quality (slow)
Advanced
- Full Screen (Keep Aspect Ratio 2)
[NOTE: Also Source Range & Clip Frame as needed per project]
GOP Stream
- Output bitstream for edit (Closed GOP) checked
Quantize Matrix
- CG/Animation
Audio
- 112 kilobits per second
- Error Correction checked
System
- MPEG-1 Video-CD (non-standard)
This generally yields an MPEG file of 785-794 MB that I burn to VCD using VCDEasy. I do not make SVCDs because I am not interested in becoming a disc juggler.
I use newgen's one disc guide along with Sefy's excellent DVD ripping tutorials. My overall process: SmartRipper | DVD2AVI | TMPGEnc | Chapter Xtractor | VCDEasy. I hope this helps!
Unta Glebin Gloutin Globin,
Akai Rounin, The Cyber Sage -
I use XVCD.. why?? because my dvd player can handle the bitrates and I am satisfied with a quality that is somewhere between VCD and SVCD. Anyhow, I usually will not go over 60 minutes on a single disc, therefore most movies fit snuggly on 2 cd's. All my settings in TMPGEnc are standard except for audio, which jumps between 128 and 160 kilobits per second and my bitrate, which with the help of the bitrate calculator is a breeze.
I went for the best quality possible route using the bitrate cap of my player and am doing XVCD's with CQ set at 90 and the cap at 2300. My audio is at 128kb and I usually get around 45 mins per CD.
I use the 480x576 resolution
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
VCD vs Half-D1 vs Low bitrate full-D1
By nharikrishna in forum Authoring (DVD)Replies: 44Last Post: 6th Feb 2011, 22:50 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
