I wanted to convert some DV footage to VCD in ffmpegX but get errors when I try. Do I need to convert to some other format so ffmpegX can read it? If so, how would I go about doing this? Also, when is ffmpegX v.0.0.3 gonna be ready, major? I can't wait for it.
ffmpeg doesn't read DV right now, you should first convert it to say MPG2 like if you were authoring a DVD. I need to find some free time to finish 0.0.3 which is almost done.
OK, thanks for the tip. I'm sure this sounds like a stupid question but what app do I need to use in orderto convert DV to MPG2 or some other format that ffmpeg will read?
huh, if you have a G4 you could try with the Apple MPEG2 encoder quicktime plugin bundled with DVDSP which is reasonably fast. When it is installed you can simply open your source in quicktime player and select Export > MPEG2. Be sure to use a proper video bitrate, ie >4Mb so as to keep high quality. Other mpeg2 encoders include Astarte M-Pack and Mediapipe. You can also try iDVD which supports drag and drop of quicktime files.
Originally Posted by SCB
ffmpegX should be used for xVCDs creation ie non-standard VCDs with higher bitrate (typically 2000 kbps) & greater image size (depending on which size your specific DVD player will accept).
ffmpegX
By rideaugrrl in forum ffmpegX general discussionReplies: 4Last Post: 26th Oct 2010, 11:21 -
ffmpegx?
By creationx in forum MacReplies: 2Last Post: 28th Jul 2010, 11:15 -
FFmpegX help
By Omipower in forum ffmpegX general discussionReplies: 4Last Post: 19th Aug 2008, 10:08 -
ffmpegX 0.0.9x r2 for OS X 10.5
By flo in forum ffmpegX general discussionReplies: 6Last Post: 16th Jan 2008, 10:15 -
what about ffmpegx 1.0?
By imp in forum ffmpegX general discussionReplies: 8Last Post: 8th Nov 2007, 10:36
