I would like to know the best way to make copies of vcd's i already own , I have tried the normal routes of cloneCD and DiscJuggler but they always produce discs that wont play in my DvD player although the original will, what I have been doing lately is to export the DAT file on the original disc to my hard drive and then using Nero to make a VCD from that file, and this works fine, however I would like to know if this is the best way or would I gain anything in quality by converting the DAT file to MPEG and then burning the disc in Nero.
nick_cunit, your pretty much doing it the right way with Nero. You might gain better quality if you convert the .dat file to a .mpg file again.
Thanks for the help does anyone know if I will gain anything in quality by converting back to mpeg or I should just carry on using the DAT file.
You should carry on with the DAT if there isn't anything wrong with it.
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19
