  1. Not sure if anyone has encountered this codec? I'm trying to convert it using virtual dub but virtual dub doesn't recognize the codec...But I have the codec installed...any ideas?
  2. Woohoo! I finally got it Ok...what you need to do in order to convert the XViD files is download the actual encoder that does it in the first place from http://www.vidomi.com - then pretty much just follow the divxtovcd tutorial on here...and you have to also install nemo's pack or whatever it says... Works perfect for me with the dvd quality.
