Hi
i drag m2v file into spruce and when go to export i get not enough disk space on media or drive..
i have 40gb master (fat 32) and a 80gb slave (ntfs) i have tried with both drives and i get same error and there is ample amount of space on both drives..
or can you recommend other software which will allow me to drag in m2v and ac3 files..
Thanx In Advance
try uninstall spruceup and reinstall what version are u using i had v1.0 and found it very buggy try update to v1.1
that might be ya prob
you can change the disk format if it is a CD-r or DVD-r in spruceUP
ChRaN :-) -
Thanks for your help guys
I have got it sorted now, it was telling me in spruce that movie was 4.4gb and naturally i thought it should fit dvd-r but it was too big.
Because i tried another disc that i have successfully ripped before and it worked..
Once again thanks for help..
tmpgenc authoring works 4 storage space error
By tommcd64 in forum Authoring (Blu-ray)Replies: 3Last Post: 3rd Oct 2011, 15:15 -
Too Much Space
By hech54 in forum FeedbackReplies: 5Last Post: 23rd Apr 2010, 17:10 -
CopytoDVD states media does not have enough space - error message
By marke67 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Sep 2007, 05:52 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 19:55
