Hello everyone!
I am currently having some trouble converting vob files...
In the beginning, i tried making divx files with flaskmpeg,
but, with no luck, cause it allways stopped at 3% of the file,
and i never got the subs either,
so, a long time after this, i formatted my pc, and tried out
some other programs.
The first one i tried was
mpgavi_016b35 (MPEG to avi) making them into divx.
But, the program stopped at the second vob file...
Result: I got a huge avi file that was unusable.
After the bad try, i tried falskmpeg 0.594 optimized for
adm and intel...
It seemed to work, but... it didnt:
There were three problems: My biggest problem, it stopped after 3% of the
videofile (like the first try),
the second problem was that didnt work to make an avi file, i
had to use the mpegprogram that comes with flask (the bbmpeg encoder or
something).
The biggest problem was that i didnt got any subtitles even i selected
them!
The next program i tried is called dvd2avi_gui.
After i had taken virtualdub and mpeg2avi there, and the divxauto
thing, i opened the program..but...
when i clicked on "start" i got:
"Nothing to be Done!"
I REALLY dont understand...why..
The last thing i tried before giving up, was the new falskmpeg..
(0.6 preview version).
But.... With that program the only thing i got when i loaded my ifo
file was: "Flaskmpeg has caused an error in
AMD.IDCT.FLASK.
Flaskmpeg will get shut down.
If the problem continiues, you should restart the computor."
So, i did restart and re-install the program, but still same problem..
Results 1 to 1 of 1
Converting Divx to VOB - having problems.
By martinlest in forum Video ConversionReplies: 9Last Post: 6th Mar 2012, 17:23 -
Converting VOB files to Mpg..
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 22:27 -
Converting .vob files to AVI
By abrathet in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 20:43 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
