hi guys
I have alot of mpg`s
but the program said that its an invaild mpg stream
i need a program to encode my mpg`s file again to get the right stream
plz help
thx alot ...
thx for replying
but tmpgenc sometimes converts to M1V
and the program i use doesnot support it
what should i do know to make the M1V to mpg?
thx again
Maybe it is mpeg2.,install powerdvd or windvd and play.
no i mean when i join the clips my program only support mpg`s
there is no M1V so how can i convert it to mpg... so i can gather the clips?
thx -
ahh i see your problem. i think you selected to only encode video.
when you chose to encode both audio and video youll get an .mpg file.
when you encode only video youll get .m1v
when you encode only audio youll get .mp2 (or .mp1 or .mp3)
so when you encode with tmpgenc choose 'system (video+audio)'
if you load a tmpgenc template, itll automatically select
'system (video+audio)' for you.
hope this helps
The best MPEG 2 encoding software?
By whatever911 in forum Video ConversionReplies: 20Last Post: 8th Oct 2012, 09:54 -
MPEG encoding for DVD
By BraDave in forum AudioReplies: 4Last Post: 4th May 2011, 00:34 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 16:05 -
MPEG editing without re-encoding
By AlanD in forum EditingReplies: 3Last Post: 23rd Nov 2007, 05:52 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 08:52
