I'm interested in purchasing the Pioneer DVR-AO4 burner. My question is this: Does it need to be installed inside my CPU or will it work alone? From its pictures it seems to be the kind of component that goes inside, but I have no vacant bays for its installation. I realize that some of you must be shaking your heads in disbelief that such a dumb question is being asked, but I honestly don't know. Thanks for your patience.
Yes, it goes in a drive bay in your case. You could also make it portable. Buy using a portable case via firewire. This case cost about $100 US. But you will need firewire port card to use this method. Which cost about $50 US.
So you have a couple of chocies. Remove a drive from a bay and install a04 or make it portable.May the force be with you.
My first attempt to backup a DVD failed...
By Inkognito in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 18:07 -
My first attempt at a bluescreen chroma key
By CogoSWSDS in forum EditingReplies: 4Last Post: 16th Apr 2009, 22:11 -
PC shutsdown when I attempt to burn DVD
By steve1040 in forum ComputerReplies: 2Last Post: 21st Oct 2008, 10:10 -
pc only boots on second attempt
By bassbinn in forum ComputerReplies: 6Last Post: 2nd Nov 2007, 15:37 -
Bizarre attempt to buy DvdFab
By VegasBud in forum ComputerReplies: 1Last Post: 8th Jul 2007, 20:54
