Hi, is it possible to capture videos from PAL VCR and then convert it to NTSC MPEG1/VCD format ? Should I capture it with framerate higher than 25 fps, and how can I tweak my capture card (WinTV PVR PCI PAL) since this card can only capture at max 25 fps ? Is it true that capturing videos from PAL VCR with resolution at 352x576,25 fps and then convert it to 352x240 MPEG1 format at the same framerate will produce smoother results than converting it to 352x288 ? Thanks.
Results 1 to 1 of 1
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 11:46
