I have too large .avi files to burn to a 700 MB CD. My burner cannot handle 800 MB Cds so all Im left with is cutting the files down a bit to fit. I followed the guide 'Cutting .avi' under the 'EDIT' section of this homepage. However, when I try to load the files into VirtualDub 1.4.10 (the latest version) I get the following messeges dependin on what file I try to load:
Couldn't locate decompressor for format 'MP43' (Microsoft High-Speed MPEG-4 V3)
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
OR
Couldn't locate decompressor for format 'MPG4' (Microsoft High-Speed MPEG-4)
OR
Couldn't locate decompressor for format 'DIV3' (Microsoft High-Speed MPEG-4 V3 [Hack: DivX Low-motion])
So how do I get these codec? How can I get the fils to load?
Thank you,
Crim
I solved the problem myself. I just had to downlaod an older version of VirtualDub (1.3) where microsoft had not tampered with the codex....
If anything that would be ASF not AVI.. Install the Nimo codec pack, that comes with all hacked codecs including M$ MPEG-4 V2,3,4Originally Posted by Crim
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 03:53 -
joining avi files with diff frame rate-error in vd
By leel in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2010, 19:49 -
Cutting/Splitting AVI Video Files Software
By Teac23 in forum EditingReplies: 1Last Post: 29th Oct 2009, 07:23 -
Joining 2 avi files, error with audio streams, need help
By leinan in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 07:12 -
Cutting AVI files by frame or keyframe?
By squegole in forum EditingReplies: 6Last Post: 1st Jun 2007, 13:25
Crim
