Has anyone been able to get ATI's MMC to record in 480x480 mode for SVCD's?
I can set Power VCD II to that resolution so it is a capability of the card.
Not sure how to do it with MMC.
~dev
Try upgrading MMC to 7.7, it has an SVCD preset.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I looked at 7.7 once and it said on the site that I cannot use it with my card.
I have the ATI TV-Wonder PCI.
Can I use it?~dev -
Have you tried Stinky's Registry tool (found on this site)? He has put a lot of great effort into creating 'templates' for creating high-quality SVCDs. You should check it out!
I personally use his tool for setting the horiz. vert. motion search features. Saves time! -
The reg tools worked I can make a profile for SVCD now. The problem is am I going to run into audio/video sync issues.
Any suggestions to avoid this before I start?~dev -
From my experience (I don't use MMC 7.7 anymore), there are never any sync issues for me in MMC 7.6. Besides, it would appear to be a problem folks have if the audio / video clocks are slightly off.
Hopefully it will go well for you (using his templates), but I have never had to re-mux using TMPGenc or other. I always cap directly to VCD / SVCD. Stay with CBR, it is less likely you would experience audio drift that way. I use VBR for everything, however, as I have not had any audio drift in MMC...
PowerVCR II, however, is a different story. I can't figure out why I have such extreme audio drift with that application... -
How do you get Stinkys program to work?? I unzipped it into a folder of its own and when i go to change profiles or load them etc etc...it says none are detected etc etc!! Can anyone help a newb get this program started?? Thanx.
Do i have to install it to tha ati file fodler?? Thanx to anyoneon this simple question
you must first create templates and name them then launch stinkys reg tool and look for those and make your adjustments...templates must be mpeg
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 13:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
