Hello,
I'm trying to rip The Phantom Menace with smartripper (v2.41)... everything rips normally and I can play the .vob file BUT the running time ain't correct!? For example: When I try to rip the first 25 parts (of 51) to make cd#1, the running time must be some 1 hour and 10 minutes but in Mediaplayer it says it's only 35 minutes long... so, encoding with tmpgenc will only result in the first 35 minutes. Ripping only part 1 is no problem, ripping part 1 and part 2 will give a difference in time of some 1.5 minutes. Part 2 is split out in many Cells. Are some Cells corrupt or is this some of ripping protection??
Tombraider had similar problems but there were Cells present which were 0KB in size, I dropped those and everything went fine... With this movie this ain't the case.![]()
well??
I thought there were some experts in here but probably I'm wrong.
ppl, I can't believe I'm the ONLY person with this problem, maybe not only with this movie but with other movies too.
So, if you have an idea to rip this movie the correct way, plz let me know! -
Media player reporting the wrong time is normal. You say 51 parts,are ripping by chapters? Tmpeg will stop encodeing from the vob file because of PTS pointers in the vob. Tmpeg reads the PTS as the end of the file. Demux the vob into an mpg and Tmpeg will encode without any problem.
I was thinkin bout rippin this movie also..... but my thing is can i fit that on a whole 4.7 gb dvd-r?????? it has to be a way because they fit that whole 2 hour movie on one dvd..... so how can i do the same thing
You would have to transcode the vob's to a smaller size with Rempeg and then merge the new m2v back into the ifo/vob stream with Ifoedit.
wulf109, wooh wooh wooh...... what in da blue hell are u talkin about
??????? i dont understand..... so is there a simpler term u might can pic???????
Best CD ripping
By magillagorilla in forum DVD RippingReplies: 36Last Post: 14th Sep 2015, 22:53 -
Ripping with Im Too
By rocks911 in forum Blu-ray RippingReplies: 3Last Post: 5th Oct 2011, 18:57 -
phantom power
By birdfeeder in forum Newbie / General discussionsReplies: 6Last Post: 25th Apr 2011, 11:03 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
