TMPGenc encoded 16:9 mpeg file? I changed the aspect ratio to 16:9 before encoding in TMPGenc, but the figures in the end product mpeg file looked squashed. Thanks.
Jeremy
I am trying to do the same thing myself... I have worked out that any Divx files without black bars need to be stretched vertically by 25%. Virtualdub can do this, so you can either re-encode (not recommended) or frame-serve to Tmpgenc (fiddly). There must be a way to do this from within Tmpgenc... anybody?
ok I am lost here...can I get a little more detail?
is the source 16:9? I know you said the source was 4:3, but does it have black bars? if there are no black bars and your video was "formatted to fit this screen" (namely, pan and scan) I don't think you can just "make" it widescreen...the stuff on the side that p&s cut off can't be gotten back...and if you do, it will look stretched, as yours did
good luck -
*Video* settings are different to *advanced* settings. Under *advanced* Source aspect ratio should be either 4:3 or 16:9 to suit the source (eg DVD), unless it's of something like a PC-originated format such as DivX, when it should always be 1:1(VGA). Generally you should start out with a Video arrange method which includes *keep aspect ratio*, unless you have a good reason not to. Under *video* setting, aspect ratio is usually set at 4:3 in the standard templates, but you can unlock these to give a result more appropriate to your display.
I think what jeremymiller wants is to vertically stretch a 4:3 AVI file so that he can set his TV to 16:9 mode and watch a large picture with not too much loss of detail, rather than just blowing up the picture and seeing every single macro-block.
I have had some success at this, frame-serving from Vitualdub. I take back what i said about it being fiddly, heres a sample (no audio):
http://www.sh014c6070.pwp.blueyonder.co.uk/sample.mpg -
Thank you for the replies. Could you briefly describe how you did it in Vdub?
Jeremy -
i think banjazzer just gave you instuctions for tmpgenc. vdub cant save a file as .mpg. tmpgenc has support for both avi and mpg but it can only save it as an mpg file.
I thought we were talking about converting avi files to mpg, for which you only need TMPG.
One hour, 37min AVI file that I want to turn into a VCD
By penang in forum Newbie / General discussionsReplies: 23Last Post: 17th Feb 2011, 11:11 -
Captured VHS to DVD didn't turn out so well...
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 24th Dec 2010, 08:20 -
Captured AVI file too large
By drgt in forum Newbie / General discussionsReplies: 38Last Post: 29th Sep 2010, 08:22 -
faint audio on captured .avi file
By coastie in forum AudioReplies: 1Last Post: 27th May 2008, 06:54 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39
