Hi,
I am brand new to this video stuff. I have a DivX .avi file that is 15MB that I wanted to convert to a Windows Media format to stream on my website at 250kbps. I read the DivX to ASF tutorial on VCDhelp here but
that tutorial uses Windows Media Tools which I think no longer exists and is now part of Windows Media Encoder 7. The link to WindowsMedia Tools was dead.
Ok so I d/l'd Windows Media Encoder to do the converting. When I tried to
convert the DivX avi file I got a 'corrupted' whatever error. So I didn't know what to do with it. I then converted the DivX file to an ASF using
vidtoasf(?) program, which worked but it created an ASF file the same size, 15MB with a streaming rate of over 700kbps. Too much for web streaming even for people with cable modems and DSL.
So I tried using Windows Media Encoder to convert the ASF file to a 256kbps WMV file. It started working fine, then it got to about 30% done and crashed the program![]()
I tried using lower bit rates, turned off the preview, and it still keeps crashing.
Damn, I just bought a new computer only a few months ago. I thought
I would be able to do stuff like this. The new PC is an Intel 2 GHZ processor with a fairly big hard drive.
I don't know what to do. If anybody could help I'd appreciate it.
Also it would be good to know why I was getting the 'corrupted' error when I tried to convert from DivX.
Also in Windows Media Encoder it seems to automatically be telling me to
output to WMV format. What's the difference between ASF and WMV format? I couldn't find out how to set the output to ASF, not that I have any idea if that might help![]()
MT
Check your original AVI for junk frames
Vdub > Video > scan video stream for errors
If it finds any
Video > Direct stream copy
Audio > Direct stream copy
SAVE AVI
Save movie2.avi
If the latest Vdub, fails on the scan use "vdub-mp3-freeze.exe" with c:\badframes.log -
Thanks for replying to my post.
I will check to see if there are any bad frames in the DivX files but that's not the biggest problem I'm having right now.
Right now I can't even convert ASF files encoded at higher bit rates to lower bit rates. Windows Media Encoder keeps crashing.
I can take a broadband stream file and convert it to a very low 56k stream, but anything faster than that crashes the encoder software.
I'm looking at the CPU load and it's running at 100%. That isn't good obviously. Surely a 2GHZ Intel processor should be good enough to convert to 300kbps stream files?
Is it possible I don't have enough RAM? I have 256MB.
Thanks for any help and advice in advance
MT -
Nothing wrong with your CPU, BUT !! XP is aaaaaaaaagggggghhhhh
for this type of work.
Converting a Windows Media Audio Video TOO MPEG-2 Format
By jhorak101 in forum Video ConversionReplies: 4Last Post: 10th Apr 2011, 16:40 -
Converting Quicktime to Windows Media Player???
By TheShape in forum Video ConversionReplies: 3Last Post: 21st Feb 2010, 17:07 -
Problem with DivX yet works in Windows Media Player
By tmundrill in forum Software PlayingReplies: 1Last Post: 18th Oct 2009, 06:44 -
converting windows media audio/video playlist files
By pw29010 in forum Video ConversionReplies: 2Last Post: 23rd Nov 2008, 12:26 -
Converting from Windows XP Media Center?
By Beev in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2008, 19:03
