  1. Need to know how to add ligos indeo codecs for using
    with dvd2avi i used the exe file but i can't see it
    in the list when i choose "save avi"
    Thanks!
  2. I'm here again
    No one knows how to add codecs in dvd2avi ?
    with others software it seems automatic ...
    HELP (cryied Beatles)
    May 2001
    London, UK - Bonn, Germany
    Maybe you have to reload DVD2AVI again?
    Feb 2001
    Berlin, Germany
    I guess, nobody knows it, because usually people use dvd2avi to decode only.
    In dvd2avi I save the project, then convert with VFAPI to a fake .avi and open that in Virtual Dub for further proceeding.
    You may try that.
  5. Yes i know that's the right way to use it but i made
    a svcd project and i would like to rework it with my
    software Video Sudio 7 from Pinnacle and the better
    way to do it is to use indeo codecs .
    Thanks for your help i'll try another codec i just
    wanted to know if there was a simple way to add this
    codec .
    Actually i'm trying with Aviutils but i've 14 hours to
    wait ...
  6. Ok that's fine i success with aviutils (indeo codecs are
    incuded) and Studio 7 is importing the file.
