Hi.
I POST THIS QUESTION IN WRONG FORUM AT FIRST.
I´M SO SORRY ALL PEOPLE.
This is my first post here in vcdhelp.com
I have a big problem and have searched the web for at solution but not find that so i hope someone here can help me.
When i try to open a avi-file in Virtual.Dub (v.1.4.10) it says "improper VBR audio encoding" and tells me that it vill rewrite the audio headers with standard CBR values but this may introduce up to 19074 ms of skew from the video stream.
Ok this messages is not unusually with aviin VirtualDub.
So i open the filen and make a new audiofile (wave) with virtualdub as i done many time before.
Then when i frameserve the avi to TMPGEnc 2.5 PLUS (ver.2.46.39.143) and use the wave (i just made) for audiosource the sound is not syncronized with the video in the mpeg i create with TMPGEnc.
When i try to watch the avi-file (movie) in Windows Media Player with subs (VobSub) both the audio and the subs are syncronized.
But not in the mpeg- which i create with the combination
VirtualDub/TMPGEnc (frameserve).
Why not??
I have had many avi-files when VirtualDub is warning about this "improper VBR audio encoding" but always it been ok after i made a wave of the audio and then frameserved to TMPGEnc using that wave file.
And burned to VCD using Nero.
But not in this case.
So i wonder what can i do to solve this problem???
The VirtualDubavi-information says:
AUDIO STREAM:
Sample precission:0-bit
Compression:Fraunhofer IIs MPEG Layer-3 Codec
Preload Skew:23040 Samples (0.48s)
VIDEO STREAM:
Frame size:23.976 fps.
DecompressorivX MPEG-4 Low-Motion
I hope there is someone who can help me with this.
PS! I have tryed NanDub also but no results DS!
Thanks.
TheFlyer.
Save audio as WAV using Virtualdub and encode using resulting WAV as audio source
"Today is only yesterdays tomorrow"
Need help with virtualdub error involving VBR encoding
By Hark in forum EditingReplies: 16Last Post: 11th Feb 2010, 23:45 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 10:12 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 09:44 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 04:42 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 18:03
in VirtualDub.
