When trying to cut a film in two i select the first half with direct stream video and audio, i then save the avi but the resulting avi only has audio for about half of the clip.
If while having a 1hr 45 min clip selected i save the wav, the resulting wav is only 45mins in length.
i hav 2 different versions of virtualdub, the one with the above problem is version 1.35d, using version 1.4.1 i hav a different problem where throughout the film the movie freezes for a couple of seconds and the audio overtakes it.
I have no idea how to solve either of these problems, i am desperately running out of space on my HD and so i need to split these films so i can put them on cd, i tried aviChop but the files it created cause mediaplayer to cause an error everytime i try and open them. I have plenty of system resources but the film still freezes, the only time it doesn't is using version 1.35d so if i could stop the audio from cutting out i could use that
PLEEEEEEEEEEEASE help me if i cant solve this problem im going to have to delete my films![]()
-K!lluminati
Did you first scan for junk frames ?
Vdub > Video > scan video stream for errors
If it finds any
Video > direct stream copy
Audio > Direct stream copy
SAVE AVI
Save movie2.avi
If the latest Vdub, fails on the scan use "vdub-mp3-freeze.exe" with c:\badframes.log
Virtualdub and audio codec missing.
By nzdreamer55 in forum EditingReplies: 20Last Post: 29th Dec 2013, 23:32 -
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 05:14 -
Codec missing virtualdub
By tkitez in forum Video ConversionReplies: 25Last Post: 12th Jan 2011, 20:42 -
Audio Source Missing from VirtualDub
By Flynn in forum Capturing and VCRReplies: 3Last Post: 5th Jun 2010, 05:58 -
Avisynth/VirtualDub - What am I missing?
By Seraphic- in forum EditingReplies: 11Last Post: 29th May 2007, 17:16
