plz...i can't find my cd and it won't rip w/ premier w/o them, anybody that can help me out it would b appreciated
I can't remember how the cd is broke down but i'm running xp pro...
No drivers are needed to run DV-Bridge. It should act like a dv-cam and would only need to be used for capture and export. XP has all the drivers to run it. Check your Device Manager, you should have, Imaging Devices and an AVC Compliant DV tape recorder/player. That's the DV-Bridge. If you're missing codecs, reinstall Premiere it has all the codecs you'll need except for like DiVX.
yup i know thats what it says...BUT it recognizes it fine but i've tried this b4 w/ n w/o the drivers, my light on the brige won't turn green( i think ) until the drivers r installed and it won't play in premier unless the drivers r installed....its weird i have no idea why but when i install the drivers it recognizes hella shit then i reset and everything works fine....it just won't work w/o them........o yea i'm capturing from a sony minidisc cam, like i said it works perfect w/ the drivers
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 13:06 -
Nvidia drivers question for new installation
By A Traveller in forum LinuxReplies: 20Last Post: 12th Oct 2011, 12:45 -
new Intel Sandy Bridge cpus
By kenmo in forum ComputerReplies: 19Last Post: 23rd Jan 2011, 12:48 -
New Intel Sandy Bridge cpu
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2011, 08:19 -
Adobe Bridge m2t files
By vegasarian in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2008, 10:39
