My VCD's are coming out a bit stretched. I.E. the faces look a bit thin and long. It isn't bad but it is annoying. I looked at the preview screen of DVD2AVI, and am convinced this is where the problem is starting. I don't see how SmartRipper could be the problem as it is just pulling down the data.
Any suggestions?
what settings are you using man?
either PAL or NTSC?
try set the baby to NTSC if you want to watch the movie on a standard Size screen when encodeing
hope that helps
F1!! F1!! F1!!! -
DVD2AVi's preview displays a 16:9 (anamorphic) .vob as 4:3 screen. That does not effect any encode setting. Just keep in mind,that it is 16:9 when you going to resize and encode.
Edit: At 2nd view I have seen,that your finished VCD are stretched as well. Yes, as mentioned, you should consider to resize.
<font size=-1>[ This Message was edited by: Truman on 2001-08-08 13:18:52 ]</font> -
Anyone up to telling me how to resize in DVD2AVI? If I don't need to make the change there how about letting me know about TMPGEnc? Newbie here who needs baby steps.
Thanks -
DVD2AVI can not resize. The easiest way is to use TMPG and as long as you use TMPG as encoder you don't need any other tool to do it.
Open TMPG, hit SETTING ,there is a "video" tab. Set aspect ratio to 4:3 525 line NTSC if you have a 4:3 NTSC TV or anything else corresponding to your TV.
Go to the "advanced" tab. Select the source aspect ratio. For example, you have a DVD NTSC 16:9 (1:2,35 widescreen), then select 16:9 525 line NTSC.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
