OK, so I'm doing some cropping with VirtualDub. And whatever I do, I can't crop the left and right sides. I'm trying to cut 6 units off of the left, and 21 units off of the right. Then I re-encode with DivX Low-Motion.
So that's exactly what I do. And I open it up. Once I start to play it, it has an error, and it comes up with that window, where it asks you to save some kind of text file about the error.
I can crop the top and bottom perfectly fine, but not the sides. Anyone know why now?
Thanks in advance.
Did you scan the AVI for junk frames before you do any work on the movie ?Originally Posted by ejp
Sounds like you are cropping but not resizing. DivX should preferably be be multiples of 16. Just any old size will not work.
[Solved] Show cropping regions [Virtualdub]
By Crollo in forum Capturing and VCRReplies: 5Last Post: 19th Jun 2011, 18:54 -
virtualdub cropping/compression error?
By popoxDDD in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2011, 22:32 -
Virtualdub cropping/resize issue
By videomanross in forum Newbie / General discussionsReplies: 12Last Post: 4th Dec 2010, 19:59 -
cropping in virtualdub
By thecrock in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2010, 10:30 -
using virtualdub mpeg-2 for cropping and need advice
By mrgain in forum EditingReplies: 2Last Post: 10th Jun 2007, 11:59
