I am not sure if this can be done ? I have a VCD format of my video holiday and right now, i am using an Imac.(VCD format extension is .dat)
In order to use the imovie software, they required for import movie in DV stream format.If i will manage to convert my vcd to DV stream format, i will be able to use imovie software to edit my movie.Can anyone here please help me about this.
Roslee
Ok, if you have a full 74 minutes, I warn you that you will have a 36 gig file on your hands...and know that iMovie requires that the movie be broken into 9 min. streams max. So this is how it is done.
Open the .dat file (VCDCopyX for OS X). Then use QT Pro to Export the video into mjpeg .mov ... then you use QT pro to break it into pieces (by hand) and export them as .dv don't worry about overlapping the dv files when breaking them up...you can sync them up in iMovie. -
Exporting your VCD-sized movie (352x240/288) to a DV stream (which is fixed in Mac at 720x480/576) will make your source material look so bad you'll want to cry.
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 00:00 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 17:53 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
