hi all,ive got 2 vcd's which play on my mustek dvd player.It says they are vcd1.1,however they will not play on my pc and tmpeg and vdub cant convert them.I just whanna know what this 1.1 thing is and get them to play on my pc.![]()
I bet if you click that "what is VCD" link on the upper left and look around there, you will find some of what you seek.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks things are much clearer now.just gotta find out how to convert the damn thing.
One option would be converting the DAT file to mpg ("how to - convert"), then re-encoding the mpg as a VCD 2.0 compliant (1150/224) mpg with tmpgenc or a similar app, then burning a new VCD with Nero (or a similar app).
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
