big mistake, needed to format my HD so i thought id go for XP ntfs, didnt realise Ifoedit only works upto win 2000, is there any other prog out there that does the same?yep im a newbie, so forgive my lame question.
i'm using Win XP pro with NTFS and ifoedit v0.88 works fine
no prombelms at all, perhaps you have an old version -
The first 4 or 5 times I tried using ifo edit with xp home edition it crashed. However I kept trying and it started working fine now it only crashes if I try to split multiple program chains such as sopranos episodes.
I use ver .91 and it crashes about once a month. -
I had problems with WinXP when trying to use IFOEdit on files generated by SmartRipper. When I switched to DVDDecryptor, the difficulties went away. Worth a try?
Yes, I am using IFOedit 0.91 with XP Pro with no problems whatsoever. I rip with DVDDecrypter and have had the system with both FAT32 and NTFS.
If you really think it is a compatibility problem, then why not run IFOedit in Windows2000 compatibility mode? -
tnxs all who helped me, esp spooki, just to confirm, i couldnt get 91 working in XP or any compatable older windows mode, i finally managed to track down version 88 of ifoedit and it seems to work fine.
tnxs guys
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 03:12 -
.ifo/.sup subtitle pair - what's in the .ifo?
By MilesAhead in forum SubtitleReplies: 2Last Post: 5th Mar 2010, 00:02 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 23:51 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38 -
using ifo edit
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:19
