  1. Can u help!
    I am trying to burn a svcd film (lets say star wars episode 2) file size
    794 mbits with nero (with svcd encoder installed)
    1 first off nero say's file is non standard complient and needs to be encoded (that i do,and waite a while....)
    2 when encoded i try to burn, it say's more disk space needed(i used 700 mbit disk)
    3 goes out and buy's a 90 min disk,nero still say's above^^
    4 i check disk space in D drive == 703mbit
    should the disk be more or do i need to do something else
    Once again thanx to anyone who replies
  2. You have to enable overburn in preferences in nero before you can overburn. Then when Nero tells you your disk in not large enough, it will give you the option of overburning.
  3. click on Author on the left and read this guide
    How to burn to SVCD with VCDEasy
    http://www.vcdhelp.com/vcdeasyhowto.htm
    Nov 2001
    Brazil
    Does you CDR drive support 99 min discs? if not, it will be treated as 80 min discs...
    Just try NERO to overburn the CD as far as you can... may work, may not...
    Fredİ
