Since I upgraded to the Pro version of TMPEG and I try to convert from divx -> SVCD, it takes double the time to convert it. First it runs once with a black screen, and then it converts the movie. Did I miss something that I didnīt miss in the not Pro version?
Sweet.
Sounds like you're now running 2 pass VBR - do you mean at 50% it starts encoding the movie (2 pass VBR) - or finishes and then starts again ?
If it is 50% when it starts and assuming you don't want VBR - then just select CBR etc in the settings. It will then encode immediately without having to run through it once - trade off is the file size ....
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
Decrease Conversion Time
By CranialBlaze in forum Video ConversionReplies: 0Last Post: 10th Nov 2010, 04:23 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 17:32 -
Removing a running time from vhs conversion
By eiffelgirl in forum EditingReplies: 10Last Post: 4th Dec 2008, 00:41 -
Double trouble with MKV conversion for Xbox360
By jayvee in forum Video ConversionReplies: 2Last Post: 20th Dec 2007, 09:09
