is there any way to lower the size of a vob file? my friend let me borrow his backup with two eps that are around twenty minutes each. i ripped my dvd but am getting each ep around 900 megs. anyway i can either a) convert DIRECTLY to a svcd or b)lower the file size? i know i can always use the guides to go to avi then to mpeg. anyhelp will be appreaciated thankx!!!!!
DVD (and so the .vob) containes MPEG-2 with quite a high average bitrate. If you want to reduce the filesize, you have to reduce the bitrate, that means reencode.
I don't think, compressing with WinRAR help much
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 04:06 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
