    Jul 2002
    NL ~ Rotterdam
    What is re-mux in the program, what is it called in this program.
    because this was een answer i got but i can't find it so it's called diferent (not direct stream)
  2. File menu --> MPEG Tools --> Simple Re-multiplex
    Apr 2002
    The State of Frustration
    "Re-mux" is called "Simple Multiplexing" or "Multiplexing" in the File-->MPEG Tools... option. Or if you have already de-multiplexed, using the main program screen to re-assemble your video again is a form of "re-multiplexing". Hope this helps.
    Hello.
