I am having trouble extracting the audio from Behind Enemy Lines Region 1. I use Smartripper 2.41 to rip the movie to the Hard Drive. The VOB’s play fine on my computer. Then I use dvd2avi 1.76. When I start the program it runs very fast and indicates audio as DTS for channel 1. When it finishes, all I have is the d2v file. All of the other channels indicate no audio and only produce the d2v file. I tried to separate the streams in Smartripper with no luck either. I have tried this on both my laptop and home computer with no luck. Any advice on my backup would be greatly appreciated.
Captain Diode
Try DVD Dycrypter. Consensus is that it is better than SmartRipper.
I use it along with DVD2AVI and TMPG with great results. -
I solved my problem.
After more testing I found that the audio stream I needed said X81 but was really X82. Once I matched the settings in Smartripper and DVD2AVI the sound was restored.
Captain Diode
Scan lines in the rip.....any help would be good
By Spinal_Core in forum DVD RippingReplies: 11Last Post: 27th Aug 2011, 13:57 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
Need to rip audio from menus
By jmelly in forum ffmpegX general discussionReplies: 1Last Post: 10th Jan 2009, 16:46 -
how to rip an audio off the net, when the audio is blocked/protected?
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2008, 11:14 -
DVD rip /avi thru MTR /FFmpegX - get wavy lines
By BattyRoy in forum MacReplies: 5Last Post: 31st Aug 2007, 10:06
