    Jul 2002
    UK (Midlands)
    Hi just wonder if anyone can clear this up for me?
    When encoding with TMPG to PAL mpg2 my source files are Divx compressed avi video file & extracted wav for the audio file.
    Now when I was creating the source avi I chose quite a high bitrate for the audio, basically what I want to know is, does using a lower/higher quality(bitrate) audio file put any less/more strain on the converting process and as a result make and difference to picture quality or frame smoothness.
    Your thoughts would be appreciated......
    Cheers
    Jul 2002
    Israel
    Hello pal,
    When encoding the audio in a lower bitrate, the only results are:
    1. Audio track quality is lower, the audio will sound poorer.
    2. File size is smaller.
    Take care
