I have been trying out iuVCR as a way to capture AVI files full-screen under XP with my Hauppauge WinTV card (Virtualdub doesn't work with WDM drivers). In preview mode I can tune into the channels and hear both channels on the speaker. But once I click record, the right channel cuts out and only the left channel is recorded. I have checked all the mixer settings etc. - nothing strange. PowerVCRII records in stereo fine, presumably using the same (Hauppauge)WDM drivers
Anybody with any ideas?
Annoying to come up with a full-screen capture solution video wise to find out it won't record the sound properly
Larry
strange! IuVCR has to be one of the best WDM cap apps around. It should work fine. Have you thought of removing powervcr and reinstalling your
drivers? Sometimes, an IuVCR beta can work wonders in situations where,
for whatever reason, capturing is not perfect with a final release copy. If you can find a beta copy of IuVCR, try that.
luck! -
Originally Posted by offline
Larry -
Larry
ATSC tuner card that captures surround sound
By Theophilus in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2011, 06:50 -
A TV-card that can show more then one channel at the sametime??
By Cazz in forum Capturing and VCRReplies: 3Last Post: 7th Mar 2010, 13:44 -
Streaming TV channel by satellite card
By starghost9 in forum Video Streaming DownloadingReplies: 1Last Post: 8th Nov 2009, 00:23 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 20:53 -
Lip sync on video captures using VIVO card
By Confused Chimp in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2007, 18:36
