  1. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Hey Guys,
    This may be an off topic, but it's somewhat a conversion thing too.
    I converted over to XP Pro from w2k. Been running smooth, but for one issue.
    I cannot delete any .avi from any of my ntfs partitions. Mpeg's are no problem, it's only .avi's, specifically huffyuv encoded .avi's.
    I have tried everything.
    I get the error that a program is still using the file. Even after shutting down and rebooting, then going straight into Explorer and Deleteing it.
    I even tried to delete through pcAnywhere from my FTP machine (another box), also from Nero's Explorer, as well as by adding a text file, then clicking that first, then (ctrl) clicking the vid clip, then delete, so if it was some sort of Explorer Preview holding it up, I could get around it............
    No luck. Any ideas or help would be greatly appreciated. THanks Guys
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Sorry Guys, I'd also want to add...
    the profile I am using is an Administrator.
    The error message states the file is in use by another program or person...
    Thank you again very much !!!!!!!
    ~~~Spidey~~~
  3. There are two options that I've used. The first is to boot to safe mode and remove the file.
    The other was given to me by a friend. I did it and haven't had the problem since. BEWARE, you are messing with you registry in this fix. I take no responsibility if it messes things up!
    Start regedit and remove the following key: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87D62D9 4-71B3-4b9a-9489-5FE6850DC73E}\InProcServer32.
    Good luck!
  4. Member spidey's Avatar
    Apr 2001
    U.S.A.
    I will give it a try pronto Bro.
    The lowest folder I want to delete, right ? I would guess that I can leave the upper structure and just delete...\InProcServer32 ???
    No worries on the dangers. I know them, and that's what Ghost is for right )
    Thank you very very much. I'll keep you posted in a minute.
    ~~~Spidey~~~
  5. Member spidey's Avatar
    Apr 2001
    U.S.A.
    You are the Man Greyhair !!!!!!!!!!!!!!!!!!!!!
    Thank you so very much for everything Bud !!!!!!!!!!!!!!!!!
    I don't know how to submit this as a guide, but this definately should be posted somewhere on site as a possible troubleshooting trick for XP.
    Thank you again so very much. If I can be of any help EVER please give a hollar !!!!!!!!!!!!!!!!!!!!
    Thank you
    ~~~Spidey~~~
  6. No problem. I found this glitch really annoying and was glad when the fix was suggested to me. Pass it on!
