I've followed all the steps posted in the MPEG2 to VCD page. Everything with DVD2AVI has worked fine, but when I select the *.mpa file as the audio source in TMPG, it says that it won't support it. Changing the priority settings in the environmental settings hasn't helped either.
I've successfully converted *.m2v files before and edited them with TMPG, but for some reason it won't work this time around. If anybody could help, it'd be greatly appreciated. Thanks.
I just tried converting an *.m2v file that is NTSC to *.d2v and *.mpa using DVD2AVI and TMPG read the *.mpa file without a problem, but for some reason, when I try to do the same thing with a PAL video, it won't read the *.mpa file. Any suggestions about how to fix this?
Just an idea - try rename the .mpa to .mp2 ?
Or change the tmpgenc settings to pal before you try and load the file in ?
I aint no expert but i try everything possible i can.
MPA to AC3
By Benjy in forum AudioReplies: 6Last Post: 14th Jun 2011, 06:52 -
Convert ac3 to mpa
By pcb in forum AudioReplies: 3Last Post: 5th Jan 2010, 12:39 -
can't open mpegs made over 5 years ago - used tmpg
By heidihagen in forum Authoring (VCD/SVCD)Replies: 3Last Post: 20th Mar 2009, 14:40 -
TMPG DVD Author 3 won't open FVFW avi
By jasoncolz in forum Authoring (DVD)Replies: 0Last Post: 7th Dec 2007, 15:21 -
Mpa to ac3 5.1
By garherd in forum AudioReplies: 6Last Post: 3rd Sep 2007, 18:43
