i would like to transfer video from my analogue camcorder to my pc, to edit it and add soundtracks etc etc, whats the best capture card i can buy, baring in mind i only hve enough money for a tv tuner style pci card.
many thanks
Please state that budget amount, so we can think along the same lines.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Then buy exactly what you said. Buy one based on BT829 bt848 bt878 or bt879 chipset. They seem to be the most compatible.
Mine is an Avermedia tv98 bt878. This company has a good rep.
I recommend it because its been trouble free and has been tested with every possible capture app around and works everytime.
But knowing your system capabilities is important also.
These depend on your system for processing power. They have no hardware compressing capability.
Anything from a p2 or equivalent will do ok. Less and you will have to cut down the rez and frame size and may be forced to use only the fastest DIVX settings for compression.
If you want full size mpeg capture you will need at least a PIII 800 or above. (equivalent amd or other are fine also)
Some applications are optimized for P3, AMD and P4.
Relatively inexpensive - cost should be less than $100 canadian
AVIAddXSubs advice needed
By betalb2008 in forum SubtitleReplies: 4Last Post: 25th Jul 2009, 20:55 -
Media PC Advice Needed Please
By jaffacaique in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2009, 22:06 -
iphone advice needed
By rhegedus in forum Off topicReplies: 6Last Post: 30th Aug 2008, 02:38 -
Streamclip 1.9.1 - some advice needed please
By shoosh in forum MacReplies: 7Last Post: 13th Jun 2008, 19:09 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
