I ripped the movie Jimmy Neutron using Smartripper. Then I imported the M2V file into Spruceup. When I simulate it has no sound. I used a guide from this site and it said that I should rename my AC3 & M2V files to be the same. So when I rename the M2V file to Jimmy, it changes it from a M2V to just a file. So when I try to import it into Spruce it cant find it because it changed to just file. So I renamed them Jimmy.M2V & Jimmy.AC3. When I do this Spruce recognizes the file and imports it but it doesnt import the audio file along with it. Is there any way to import it myself? Any help sure is appreciated.
Thanks Boxingjunkie
Results 1 to 9 of 9
Try renaming the file extension of your audio file to '.mpa'
both files must have the same name (As you mention) -
You import the following file into the Spruceup MEDIA ASSETS area:
MYFILM.M2V
Spruceup automatically imports (from the SAME directory):
MYFILM.AC3
or
MYFILM.MPA
Don't know what will happen if both of the above audio files are in the same directory (probably total protonic reversal). -
Still no luck. I changed the audio file to Jimmy.mpa and it still didnt import it. Any more suggestions? Im just not having much luck here.
Thanks Boxingjunkie -
i use spruceup dvd for all my dvds like they say rename the files
eg
spruceup.ac3
spruceup.m2v
dont forget to put the file extensions on the end!!!!!!!!!!
You video is already imported. Once you change the name of the audio file, re-import the video (takes only about a second this time). Spruceup will now see your audio file and import this also.
I got it this time. I changed both file names to just Jimmy. When I would change the M2V file to Jimmy it would change the file extension name from a M2V file to just file. So when I went to import it into Spruce it wanted and M2V file. I just clicked on all files hit Jimmy and it imported both of them this time. Thanks for all the help. Im on my way now.
lol [At least you are on you way to the NEXT major hurdle!] yep u got it there have fun keep ripping!!!!!!!!!!!
[/quote]
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
