  1. When I go to Build DVD it starts out OK but when it gets to "Build UDF Image" it gives me an error: "Mux: Invalid video error." Does anyone have any ideas. Is it better to create a seperate video and audio stream for DVDs (I heard dvd players don't like MPEG 2 audio).
    I tried to create a video only stream (not a system/program one either) in TMPGEnc but after it encodes it gives me a resolution of 720X540 and I selected NTSC and 720X480 on all settings. Impression gives me an error (I expected it) as soon as I try to import this file.
    Would getting Impression Pro instead of SE make any difference?
  2. I found a lot of info on this error in Pinnacle formum, apparently your audio should be in PCM format 48khz 16 bit, or in AC3. AC3 though should be created with frames in Motorola byte order, if you save your AC3 with "intel byte order" then you'll get that error. Also i think pinnalce wont let you use mpeg audio in NTSC project, because it conflict with DVD standards for NTSC, PAL project can use mpeg audio
