I have a 2.3gb SVCD file that I have been trying to demultiplex into a .m2v format so I can use it in my DVD authoring package. When I run demultiplex it only creates a .m2v file that is 706mb big. The .m2v file is fine but it is only one third of the movie. Am I missing a setting in TMPGEnc that sets the output file size? It's a great program but the help really sucks!
Thanks in Advance
I know what you mean. I had same problem and it's not easy to get round. First thing is to make sure you don't use tmpenc to join the svcd mpegs it don't do it right use movie combi or borland mpeg joiner to join the files and it it still don't demulltiplex us Xmuxer to demux the A/V. Then u can use tmpenc to reencode to put to dvd or whatever. Hope this helps. What dvd authour package u using?? i use spruce up but it's giving me alot of problems at the moment and won't create my chapters.
Thx Acolonx... I'll try your suggestion. I joined the three different svcd segments using CM's DVtool. It obvously wasn't a clean join! Believe it or not, I live in a mixed world. I do my file manipulation on a PC (better tools for this) and my DVD authoring on my dual g4 Mac using DVD Studio Pro. Great app! and I have never failed on a DVD burn! THX again...
Conversion or demultiplexing of TRP files
By ranmamez in forum DVB / IPTVReplies: 2Last Post: 26th Oct 2011, 09:50 -
out of sync when demultiplexing
By calanda in forum Authoring (DVD)Replies: 5Last Post: 5th Aug 2010, 02:04 -
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 02:55 -
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 21:57 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
