I am using TMPeng to convert. I have done this several times. The movie I am converting will play fine with video/audio in Win Media player. I choose the movie file in tmpeng. The file will show up in the video line but the audio line is blank. I try to rip the audio using virtual dub and it says
"The requested audio compression is not compatible with the input format. check that the sampling rate and channel count of the input match those of the requested format"
Anyone one have ideas?
TIA
48khz ripped audio trying to be converted to 44.1khz audio without downsampling. Best choice encode to 48khz by changing sampling frequency under settings, audio. ACM station and SoundForge will downsample 44.1k if you must but you are asking for sync problems.
MPEG1 -> MP3 conversion possible in DOS?
By Figge in forum Video ConversionReplies: 3Last Post: 25th Mar 2009, 08:05 -
AVI Conversion - Audio out of sync
By pinovecs in forum Video ConversionReplies: 3Last Post: 17th Oct 2008, 16:11 -
Audio Offset In Avi Conversion
By Scav2003 in forum MacReplies: 4Last Post: 4th Feb 2008, 13:26 -
MPEG1 to H.264 conversion
By sarvagya in forum Video ConversionReplies: 5Last Post: 14th Dec 2007, 03:25 -
audio conversion in avi file
By Ogilvy in forum Newbie / General discussionsReplies: 4Last Post: 30th Aug 2007, 19:35
