I have a JVC XV-S60bk, and it plays all vcds fine, but my svcds fail to play. They are jumpy/choppy and hiccup in the player. Aside from re-encoding, I was wondering if there is any way the SVCD could work. I have tried multiplexing as VCD(Non-standard), but it still fails. Any suggestions would be appreciated. I noticed that some ppl who reviewed the player said it can play SVCDs perfectly, so I was wondering if I was doing anything wrong.
My method:
1. Use vcdgear 3.07 to convert from bin/cue to mpeg2.
2. Burn mpeg file with nero @ 4x on Memorex cds.
NOTE: I have tried multiplexing before burning.
Any Help will be appreciated because I really want to avoid buying a new player.
You don't mention the bitrate but sounds like that may be the problem. Try lowering it in stages till you find what your player will handle.
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 10:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
high bitrate h.264 looks like junk???
By RadicalxEdward in forum Video ConversionReplies: 14Last Post: 12th Jan 2008, 20:38 -
High Bitrate Flash FLV
By Soopafresh in forum Video ConversionReplies: 1Last Post: 24th Nov 2007, 04:04
