I just bought a brand new HP 100I and need to install it.
Here's my issue:
My PC has a cd-r drive 16x, a DVD player 12x, and two Internal HDD 20 & 40 Gig. My tower has two extra external drive slots, but my MB only has 2 IDE slots. Is there an IDE cable that can hook up 3 or more devices (or mabey some sort of splitter?). If I do need to remove one of the Ext drives to use HP 100I, which should it be the CD-r or the DVD? Do I need the DVD to play discs and to back up discs with the DVD+rw. I'd like to use all 3 drives if possible.
Thanks for any suggestions.![]()
Also, does anyone know if HP is extending the $99 DVD + rw trade up program past 6/30?
pcdvd123,
I think you'd better add a PCI IDE RAID card to your PC, or sell either 16x CD-R or 12x DVD-ROM drive. Only up to two devices per connector. I often used more than ten IDE devices in one PC so I had to use on-board or off-board (PCI) IDE as well. Promise ATA/133 PCI cards cost under $30 now.
No, I don't think HP will offer any such program again.
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Do you install software from the cd/dvd or go straight to the website?
By yoda313 in forum PollsReplies: 11Last Post: 18th Jun 2008, 15:10 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
how do install two folders video_ts in one dvd-r
By togood in forum DVD RippingReplies: 3Last Post: 13th Dec 2007, 06:58 -
DVD playback software without install
By sugeknight in forum Software PlayingReplies: 4Last Post: 12th May 2007, 11:59
